Nous sommes le Lun 21 Jan 2019 16:43
Ghibli de Hongrie [ENG]
Re: Ghibli de Hongrie [ENG]
Messagede alpa » Lun 28 Mai 2018 12:06
spacecadet a écrit:So I can either adjust the difference between the exhaust and intake cams by changing the pin in the sprocket in the back, or just change the chain since I already have it. By the way found the manufacturer mark on the chain: https://www.reginachain.net/ They mainly do chains for motorcycles, another Ducati connection like Nigusil?
Interesting ! Have you tried to contact them ?
I can not help about the shaft you tried to dismount. Honestly speaking I did not understand what you were trying to do.
Messagede spacecadet » Lun 28 Mai 2018 18:37
alpa a écrit:Yea this does not look right.
I'm sorry I did not read the entire thread. I guess you've checked first that there is a lash between cams and buckets ?
Your valves may have been burned if timing/richness was wrong and combustion was continuing with open valves.
Yes, double checked to be at TDC at the end of compression, and that there is a lash between the cams and buckets. First I though I'm at the wrong TDC, but unfortunately not.
I've measured AFR earlier with a wideband lambda, and that seemed to be ok (I don't remember the exact numbers) but that was after I've replaced the out of spec sensors. There was definitely a rich situation I think earlier.
alpa a écrit:Interesting ! Have you tried to contact them ?
Not yet, but I just wrote them an email. Will see.
alpa a écrit:I can not help about the shaft you tried to dismount. Honestly speaking I did not understand what you were trying to do.
Thanks, It's already done, it was just very tight. I had to remove the bearings first.
spacecadet
Messagede alpa » Lun 28 Mai 2018 19:07
Oops, me too !
Ok I see.
For your information you can mount old (before ABS) axles with their wheel hubs on these hub carriers. Perfectly compatible. This allows mounting old rims with the 96mm instead of 98mm (or the opposite, don't remember) center distance.
Messagede spacecadet » Lun 28 Mai 2018 20:03
Forgot to show these pictures. One exhaust valve is leaking. Is this white color normal? Could it be because of the additives in the modern fuels or it's burned?
spacecadet
Messagede alpa » Lun 28 Mai 2018 23:31
Modern fuel is not unlike 30 years before and modern valves are similar to what we had on biturbo engines.
This white color is not unusual on exhaust valves. It forms a kind of very hard ceramic, not necessarily lean combution. You'll find the same on the piston crown. For sure it was not running rich. May be a bit too much white especially on valves themself.
I can show you beatifull pinkysh valves from 3200gt.
Messagede spacecadet » Mar 29 Mai 2018 22:56
That's good news. The results are still hard to believe for me, so I'll triple check everything once again.
spacecadet
Messagede alpa » Lun 25 Juin 2018 08:16
spacecadet a écrit:Yes, I've fixed the pictures :)
Finally did the leak down test, should have done much earlier. The results are really not good, nearly all the cylinders show 25% leakage, regardless the number there a lot of air is escaping at the exhaust valves.
https://www.youtube.com/watch?v=XyRx4Bmjmq0
I don't think this is acceptable, I fear this means the heads should be removed. Could be burnt valves (they are pretty white)? Any suggestion?
I've made leak tests on different engines this week-end.
Primatist (2L 24v probably totally rebuilt, low compressions, not enough power) and my 2.24v (engine on the bench, 120mkm): 20-25% of leakage, same on both.
430 18v with a 180mkm engine: 5%
222E (2.8 18v) : 0%
Would high leakage be due to low tension piston rings ?
Messagede spacecadet » Mer 27 Juin 2018 07:50
Interesting. For me most of the air was escaping through the exhaust valves, some through the intake but couldn't feel anything through the crankcase though the oil pan was not removed.
After a long hesitation I've removed the head on the weekend. Glad I did because the gaskets were fully deteriorated unfortunately even pitting the head in some places. I've also found one combustion chamber with really strange marks, but nothing on the corresponding piston. The piston is still on the top, I have to block the sleeves to turn over and see the cylinder wall. The other walls look nice with clearly visible machining marks.
I think this head will need resurfacing (or I have to find other ones) but I wonder if that's possible. The intake valve seats are angles are dangerously close to the surface of the head. The manual calls for measuring the combustion chamber with fluid and plexi glass that can't be laid on the surface as the valves are protruding.
spacecadet
Messagede spacecadet » Mer 27 Juin 2018 08:08
By the way, did you get an answer from Regina chains? I didn't...
spacecadet
Messagede alpa » Mer 27 Juin 2018 08:32
I did not get answer from Regina, not surprising, Maseralfa explained in Italy you have to call before writting to them :) .
He'll try as a professional, he owns a parts business.
Your head looks like having had strong ping, ping melts down the surface. But it usually happens on pistons, not on the head. At least I have not seen such case but I don't have so much experience with this. Check piston crown when it's in TDC. These heads are extremely well designed so they are very well cooled. And pistons are forged. So it may be OK after some cleaning and surfacing.
Valves are OK and yes they are close to the surface but this is how F1 heads are :) . It's written Coscast, not a mistake, it's Cosworth.
Head oxydation is not unusual on old engines. You'll see more once surfaced, removing 0.1mm may suffice.
Note that valve seats are very special (round shaped like on F1 engines, not angled) so don't allow any wanker to work on them. There is only one angle on them.
PrécédenteSuivante
Retourner vers Nos Maserati
Qui est en ligne
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
