Nous sommes le Ven 18 Jan 2019 14:28
Ghibli de Hongrie [ENG]
Re: Ghibli de Hongrie [ENG]
Messagede spacecadet » Mar 10 Avr 2018 14:21
No check engine, no smell. I guess because it's just a small crack there was no visible leak. The visible leak was at the exhaust port of the head.
I thought about welding, but the places I've contacted with couldn't guarantee the outcome, I've just found a place who claims 100% success with thermal sparying of metal.
spacecadet
Messagede plm » Mar 10 Avr 2018 15:13
spacecadet a écrit: I've just found a place who claims 100% success, with thermal sparying of metal.
Can you ask them for an example of work? Or a sample?
Messagede Froggie » Mar 10 Avr 2018 16:08
spacecadet a écrit:No check engine, no smell. I guess because it's just a small crack there was no visible leak. The visible leak was at the exhaust port of the head.
Interesting.
I thought drilling was necessary to block the crack tips, and welding to have a perfect re-bonding of the crack (plasma may only "coat" the substrate with fused powders).
But this video shows that it may work well if properly done:
https://www.youtube.com/watch?v=hoaPSaNYl34
Look in particular at how they pre-heat the substrate to high temps before starting thermal spraying and thereafter melt in a controlled way both the powders and the substrate to close the gap.
Also noteworthy is the fact that they have apparently drilled the cracked zone before starting the heating/spraying process as it is essential to avoid propagation of the crack at the tips.
Not sure however if stresses (promoting further cracks) may not develop during cooling... Probably needs some annealing afterwards.
Hope your shop does a good job!
Messagede spacecadet » Mer 11 Avr 2018 10:23
The process is pretty much as you describe. Preparation is the same as when welding, drilling and grinding. They heat up the whole part so not only the small areas get high heat. Then comes the spraying and melting. Afterwards annealing, cool down time is around 2 days.
I also hope they do a good job :) but they do similar works regularly and I have seen reference work.
spacecadet
Messagede spacecadet » Mar 24 Avr 2018 22:17
So here is the result after resurfacing. The repair was pretty expensive (because of the powder used in the process), but also included a crack test, which revealed a smaller crack on the other side. All in all 145 EUR + 35 EUR the resurfacing. Still cheaper than a used part. And I will probably do some grinding work to remove the protruding parts.
spacecadet
Messagede Froggie » Mar 24 Avr 2018 22:49
Thx for the feedback and well done.
Btw, if you have some spare time, you should reload your previous pics in the thread (not visible anymore).
Just click on the image, then change the extension from postimage.org to postimage.cc in the web address
Messagede bay » Dim 29 Avr 2018 10:39
Froggie a écrit:Thx for the feedback and well done.
C'est corrigé ;)
Recherche toutes informations au sujet des Maserati Gransport MC Victory , le registre Gransport MC Victory
Ghibli III V6 3.0 330 cv Grigio Maratea 571 Image
"Playboys are driving Ferrari and Gentlemen are driving Maserati"
Messagede spacecadet » Sam 26 Mai 2018 19:30
Yes, I've fixed the pictures :)
Finally did the leak down test, should have done much earlier. The results are really not good, nearly all the cylinders show 25% leakage, regardless the number there a lot of air is escaping at the exhaust valves.
https://www.youtube.com/watch?v=XyRx4Bmjmq0
I don't think this is acceptable, I fear this means the heads should be removed. Could be burnt valves (they are pretty white)? Any suggestion?
spacecadet
Messagede Froggie » Sam 26 Mai 2018 19:57
Goddam...that's annoying!
I'm no expert but wrt leaks, maybe only the valve seats may be reworked?
But then it may be worth rebuilding the whole heads.
Experts will chime in
Messagede alpa » Lun 28 Mai 2018 12:00
Yea this does not look right.
I'm sorry I did not read the entire thread. I guess you've checked first that there is a lash between cams and buckets ?
Your valves may have been burned if timing/richness was wrong and combustion was continuing with open valves.
PrécédenteSuivante
Retourner vers Nos Maserati
Qui est en ligne
Utilisateurs parcourant ce forum: Exabot [Bot] et 2 invités
